uglytruk
- Joined
- Oct 24, 2004
- Posts
- 1,329
- Reaction score
- 0
I removed my LF axle to change the u-joint last nite, and retracted the caliper piston a bit. Pads were so-so. Up until then the pedal was real nice and high and firm.
Now it's low and the hydro boost squeals. The fluid was very low, so I topped it and checked for leaks, none. It's a mostly rust-free Oregon TEERUK, so no rust on lines. The pedal DOESN'T sink like a weak master, and responds to pumping it up.
I locked up the left front and rear tires on snow, so at least the left side brakes work.
Usuallly when the caliper is retracted, a couple of pumps, and all is well. I just moved the piston less than 1/4", and the wheel locks, so it's working, but the pedal is REAL low!
I installed new pads on the right side a couple thou back, weird that the rite was down to the rivets, but left not quite 1/2 worn... the rotors are as new...
