F-ingrob
Wheres the mud
Need help
Rear window wont go up either from the switch inside or the key outside
I checked all the connections and found nothing lose it would do it once in a while before but now i had to use a drill motor to make it go up
How does it work
Is there a relay hidden or a door switch not making connection
How hard is it to go to a manual window regulator
How does it work
