It's about wheel travel vs shock travel. If you mount the shock at an angle (inward for articulation or forward/backward for go fast travel), then the shock will still be the same travel, but the as the wheel moves up, since the shock is at an angle it only moves part of that. So what happens is the wheel can travel more straight up and down than the shock travels at an angle. In doing this it puts more force on the shock so in order for the shock to have the same effectiveness it needs to be tuned stiffer.
I was saying to mount the shock partway up a lower link arm. If the link arm is 4 ft and you mount the shock at 2 ft for example, every time the shock moved 1" the wheel would move ~2" . That's a little extreme and not exact because its an arc, not linear. One would probably do more like 3 ft on a 4 ft arm, so the wheel travel would move 4/3 or ~1.33 x the shock travel. Then if you angle the shock forward you can get even more wheel travel from the same shock travel. But then you get more and more angle as the wheel gets closer to full bump, which is not good. You'd rather have it more straight(or perpendicular to the arm) at full bump. That's a whole different subject.
OK, that makes sense, you're putting the shock on the link arms rather than the axle. I've seen that done a lot on the race trucks, and it even works for me with the limited geometry knowledge I have...I missed those two words at the beginning of the post...which seems to be the right way to do it, although by far the most expensive. I may end up heading that way eventually, and the PO of this truck told me he had originally intended to link the rear, so he had set things up with that in mind as he built the rear. It's a big step, though, and I'm not sure I really need all that travel...but I don't need most things I have. Thanks for the explanation, though. It's kind of along the lines of me thinking maybe I could put a shock on the anti wrap bar up closer to the middle of the truck. Problem is, I would only have one.
