I found the middle section (float bowl) to be warped on the top. How would this be made strait in the vise? Also great thread.
dyeager535 wrote:
Ahh another note. Don't take the throttle plates off the throttle shafts (unless you have to, like to bush the primary throttle shaft) as you run the risk of breaking the small screws off. You can grind the staked portion off, etc., but not worth it if the shafts don't HAVE to come out.
