Hi
I'm currently doing the cab floor and the rocker panels and have a few questions:
1. Is the rocker panel somehow attached to the cab floor? I know it is by some spot welds at the front and back and the pinch welds on the bottom. But I haven't seen any welds on the top. It's also loose if a wiggle around with a screwdriver.
2. How should I replace the front cab mount, the footwell (that triangle part) and the rocker panel?
My plan is this order:
- Replace front cab mount
- Replace the footwell (without attaching it to the rocker panel, but attaching it to the front cab mount)
- Replace rocker panel (without spotwelding the pinch welds on the bottom)
- Replace the cab floor with the inner rocker panel (and attaching it with the pinch welds to the rocker panel and attaching it to the front cab mount)
The cab is already braced, but I think a will put and additonal strut between the lower A pillars
