Venanzi85
Registered Member
Asking 8k but I’m negotiable on price
***update just installed a 750 CFM Holley double pumper and now it’s running and idling great.
For sale is a 1977 Chevy K5 Blazer soft top not including just hard top but it can be negotiable if you want soft top as well. which has the sliding glass on both sides.
currently has a 4 inch lift with 35 inch tires (only 1k miles on them)
350 SBC V8 with Auto Trans (TH350)
Clean NC Title in hand
what's new
Driver side and Passenger side door weatherstripping, Transmission modulator,fuel filter,air filter, fuel sending unit, spark plugs, body mount bushings and hardware, rear drive shaft (built by Oliver's in Winston Salem) , Steering Column was rebuilt, all new bushings and races and much more. Steering Stabilizer (Rough Country) alternator, battery, new stereo, and speakers, both driver and passenger door panels, side view mirrors, rear bumper, rear tail lights, headlight bezels, just recently installed hood latches and hood latch cable, (used to just have the hood pins) hood hinges, I also have that will be included with the truck are new valve cover gaskets, transmission gaskets, gauge clusters and gauges to go with it plus other parts. The center console is new. just recently installed a Tach that works. Vacuum advance. Dual Exhaust with Thrush Mufflers (PO had dual exhaust but with glass packs) Dimmer Switch. Emblems are not reproductions, they are original.
Currently I have no carpet in the back because I was going to do a bedliner.
*The bad: has no parking cable (however i do have the parts to install just have no got to them yet)
fuel gauge works intermittently, believe its a ground, oil/temp gauges do not work but did install aftermarket ones that work. no a/c or heat, no backseat did have one but i sold it. will need new draglinks
not a lot of rust on this truck, but will need some body work as PO I purchased from 2 or 3 years ago has some bondo on certain places
The paint is awful like that when purchased, truck was blue originally but PO decided to paint it red that will need to be addressed at some point.
last but not least currently it starts but I can not get it to stay at idle, I recently installed the new carb this January and had it running just needs to be fine tuned, I am still currently working on it, I know I can install old Carb and it will run and idle just fine when I purchased it.
I do have the gauge bezel just need to put back on
There's so much more I could write about this truck,just please txt or call or come see it in person, I really do not need to sell just testing the waters.
Ive done alot to this truck to get it to where it's at now, this could be a good toy or weekend driver, or with a little more work a daily driver.
Please if you have any questions feel free to ask.
what's new
