chevyguybc
okay , while im into the heart of the beast I think I should replace it as well, how the hell do I get it out and the new one back in
87 4x4
87 4x4
I have a nifty trick for you to try out!
Shove the end of your grease gun into the bearing and start pumping grease in there. It isn't well known, but your grease gun makes something like 2000 PSI of pressure if you can pump it right up, and it'll pop the bearing out using just hydraulic pressure. No damage to thrust / main bearings, and just requires you to clean the grease out of the end of the crank before installing a new bushing or bearing (go bushing IMO!)
