This is what i did to get my kingpin out.
-Get a 4 inch angle grinder and a very thin cutting disc. Cut a deep groove all the way around the kingpin that goes to the shank. Make cut ALMOST to the underside of the kingpin head where the kingpin touches the C
Once cut is made (about 3/8" deep), take 7/8" chisel, put 7/8" boxed end wrench on the chisel, insert chisel in kingpin upside down, put a 1 1/4" wrench over the open end of the 7/8" wrench and give a small tug. It will break loose.
Total time takes about 5 minutes per kingpin.
No heat, no broken tools.
This works real well.
Mike
Mike
but it worked very well!
