Got a good running engine, and want to replace the headbolts with ARP studs...OK to do one at a time so as not to disturb the gasket?
what about torquing them in steps..is it needed or not?
if you are going through the expense and trouble of studing it.
. I know that it's common place to lift the cab when doing head gaskets and studs , I was thinking that some of the holes were simply to close to the cab to be able to slide a stud into, but , like I said I may be wrong.
