IVE OWNED MY 91 JIMMY for 11 years, its been mostly babbied all of its life, (even before me) but its got 268000 mi on it (34000 on goodwrench stock crate motor) and about 30000 on goodwrench 700R4, but the springs are spongy and the bushings are all dried up. So, Ive got a skyjacker softride 4in (Springs front and rear) all bushings,shackle bushings too, and oe cab mount bushings. extended stainless brake lines,dual steering stabilizer, Bilstein 5100 shocks for all 4 corners,t-case lowering kit (questionable) raised steering arm and all new bolts and hardware. Putting BFG mud terrain KM2 35-12.50 15 on 15x10's. Im hoping this will handle good and ride pretty good, Its mostly a daily driver (on road) with occasional trips to the lake pulling the boat with the top off. Any input on that combination of parts or tips on making it better?
. and imo those tires aren't a very good choice for a daily driver. you may need a zero rate out back as some lift kits will sit lower in the back, especially on a K5 as it's heavier in the rear than a K10......you'll know after it's all in.
, should you want to bust some trail moves.
