rim size options for a 14b
wildman29
Registered Member
alabama
so i got my wheels/tires/lift delivered last week, and now i am getting a 14 bolt next week. my question obviously is will 15 inch rims fit on a 14 bolt. i know i will have to get new rims because of the bolt pattern but i just bought the tires too. one of these days maybe i will learn to do these projects in the correct order LOL. thanks, Josh
well if no one will help I guess I will. I'm 90% sure that you can fit 15" wheels on a 14bff
Either disk or drum... you should be able to run 15's with up to 4.5" BS with a little grinding of webs/casting flash. May not even have to grind at all.
ok thats great news as i havent even mounted or balanced the tires yet. thanks for the info, Josh
why are people so afraid of 17's? and still sticking with 15s and trying to cram them on D60s........I don't get it. lots of good tires are availiable in 17 now. I believe 17s are the new wave. especially newer stuff with bigger brakes.
i agree
even more so on the front 60's
the amount you have to grind off a 60 brake caliper is retarded IMHO
Have you guys found a decently light wheel in 17's? I to am thinking of dumping my 16's and go 17's when I need new tires cause of the selection available and it seems all 16" tires are super high load with monster sidewalls.
I like my aluminum H2s they're 17x9....and aluminum. and can be fouund for cheap.
the selection is out there.......and it'll improve all the time and 15s for truck tires will disappear. you watch.
15s are for hondas...........
Big91RustyBucket said:
17's are sweet I had some on my other s10 on my 1 ton's but the only problem is the lack of support from swamper on 17's. :( Then need a more broad line-up for those who don't want radial.
i have IROK's in a 42" on my H2's and love them
I know but interco needs to catch up to the wave of the future. I feel no need to grind calipers with the broad selection of wheels. As I said only issue to me is Interco makes primarily 15 and 16.5 as their main tire selection. Anything other than that the selection goes down hill .
Yes, 16" or 17" such a conundrum, I went for 16.5". You know, split the difference:D Ok, lame joke:rolleyes:
I had 15x12s on a 2.75 BS on my old truck too..........but I've SEEN THE LIGHT Brother!!!! Hallalluja!!!!!! Can I get an Amen! AMEN!!!!!
