Rock sliders/boat siding...call it what ya want but either way, I gained clearance.
Cut 5.5" of body away.
Most of it was junk, either bondo or rust so no big deal.
Once I cut the rocker out (what was left of it) the door sagged terrible due to the inner kick panel that was no longer attached to the floor because of rust.
To cure that I laid a tube along the floor and welded it to both the floor and the inside of the kick panel.
Then welded in a vertical tube from the first tube, up the kick panel and tied it into an existing firewall support.
No flex now.
The rock sliders were "as built" working with what I had to deal with.
(existing tubing for the roll cage mainly)
Mounted to the frame in 5 places with cross bracing on each tube, as opposed to the original rock slider that only had three tubes with zero extra bracing. (say stress riser)
Used up most of the 20ft stick of 1.75 DOM doing it too.
The saw horse pics show the 'before and after' the best.
No flex now.
