So if I wanted to run a wire direct to the back of my 1974 Temp gauge, which has 3 prongs, which prong would I put the wire on?
If you have multiple gauges going out at the same time, I'd make sure the grounds are good. Not sure how yours is, but I always check grounds when things have a mind of their own...
Yep, both of them need +12 to work. And it looks like they both get it from the same wire.
When do they quit? Do you just crank it and they are dead? If so, I would suspect a problem in the ignition switch.
Well, kinda. The schematic you have shows part of it. Look at the ign label on the temp gauge. It is the power supply for that gauge.Do you have the schematic that shows that wire?
near Huntsville...north alabamaAt this point, I am not going to rule anything out. A shorted sending unit wire should peg the gauge.
But, if it shorted to a hot wire somehow, who knows?
What part of Al are you in?
