The spare tire I have is a smaller sized tire. If I were to get a flat on a rear axle tire I think it would be best to place a good front tire on the rear and use the spare on a front axle tire. Your thoughts?
Actually if you don't have a locker in the rear, it's safer to keep the front tires same size and the rear differential will take the slack, it won't even feel it.That is correct. Put the incorrect size tire on the free wheeling axle, it causes extra work but prevents potential damage.
I'm not sure the oversized tire will fit in the factory spare tire location.Just get the correct size spare and be done with it.
I would give it a shot if you haven’t already . I was pleasantly surprised to find the almost 34” tire fit in the stock spot in my grand Cherokee.I'm not sure the oversized tire will fit in the factory spare tire location.
