handloader90
Building!
Hey fellas,
Somewhat Chevy related. Looking for some recommendations.
I've got a '53 Willys CJ3A. It currently has the 4 cylinder L134 "Go Devil" in it, every bit of 60 horses lol.
I'm planning on doing an engine swap and I'm having a hard time deciding between a Toyota 20R or 22R 4 cylinder or a 350 SBC.
I already have a running 350 SBC. I've found a running Yota 20R locally for $250 that I can pull out of the truck.
The 4 banger only has exhaust on one side of the engine vs. both sides on a SBC. Distributer on the front drivers side of the engine vs. back center on a SBC.
Transmission will either be a SM420 or SM465, I know where multiple of each tranny are for dirt cheap, transfer case will be a Jeep Dana 300.
The transmission I choose only depends on which transmission to t-case adapter will give me the shortest overall length. I know that a SM420 is 10.4" long and a SM465 is 12" long. I'll get on Novak and Advance Adapters and see who has the shortest adapter per application and come up with the shortest combo possible.
There is a company that makes a bellhousing adapter for Yota 20R/22R engines to Chevy transmissions so that is covered.
I know that if I go Yota/Chevy/Jeep everything will have an adapter but I'm thinking the Yota 4 banger may be the best option.
Can't use Toyota everything due to the length of the transmission... it would be ideal to not have to adapt anything but I need a rear driveshaft in this super short wheelbase Jeep.
Tell me what you would do.
