runamok151
1 ton status
x2
I used to keep a pair of 5 and 10 lb CO2 extinguishers in my truck. Now I have two of these elements
x2
Log onto Progressive, and up my coverage.OK first off don’t go ADD on me.... read the entire paragraph before you respond please!
Fire is one of my biggest fears. So as I’ve played this scenario in my mind a few times what would you do if you realized you had an engine fire?
Let’s start old school and say you have a 77 Blazer with a mechanical fuel pump and a carburetor. And we will get into later model equipment (higher pressure fuel pump and fuel injection) later in the thread
Don’t they have the fire supression mat for underhood insulation that drops down to smother
Do the opposite of this guy.
Exactly. As much as we all like to see a funny video this really shows what can happen when there is no plan. This guy had no fire extinguisher and had never thought about plan B. He kept cranking but that only works for a backfire through the carb. Had he immediately pulled off his shirt and smothered the small fire, the large panic fire would not have started. Had there been a fire extinguisher handy also no big fire. @76zimmer has done a good thing here making us think ahead so when it all goes wrong we have a chance at doing the right thing.Did he pickup a gas can? In a desperate situation people do desperate things. I hope he is ok.
I sell the Element extinguishers, and they are definitely a unique product. I keep one of them in my truck as well as a conventional extinguisher.
I have two of the Elements,the large ones. Hope they work as advertised.For those with Element extinguisher knowledge / experience, when stored is it ok if they get wet? I don’t have a top for my Blazer so everything is subject to wheeling, washing and weather elements.
As for a plan, obviously shut it off and get everyone out. I plan to have fuel (TBI pump) and ignition cut off switches for security so the fuel pump cut off would be important during a fire.
shut engine off, don't open hood, use fire extinguisher through grill. No fire extinguisher ..... for shame.. open 2 liter bottle of coke, place thumb over opening, shake the $h@t out said 2 liter and spay with thumb over opening through grill.
Done that, it worked. Old carbed 350 backfired through the old worn exhaust flapper valve thingy on the pass. exhaust manifold. It ignited the caked on gunk around it. Had about a quarter of the 2 liter left for the ride home.
I do have a '77 and '79 K5. I have a fire extinguisher in the back of the '79, just for CYA. It's the full size, not the aerosol type.OK first off don’t go ADD on me.... read the entire paragraph before you respond please!
, and there was no lasting damage, just a few hours I had to spend cleaning... I think a more concentrated shot directly onto sensitive equipment might do some damage.
