bp71k5
3/4 ton status
I need to replace my battery clamp after doing a lot of rewiring. To avoid having lots of battery leads coming off the top post on the battery, I'd simply like a battery clamp/cable with two 4ga outputs. One output goes to the starter and one goes to a junction block that runs the rest of the trucks accessories.
I found lots of options for stereo equipment similar to this:
http://www.sonicelectronix.com/item_17809_Kicker-CBP-09CBP.html
I guess that thing will work, but I'm not that fond of using set screws on cables. I'd rather crimp or solder them. Does anyone have links to anything similar? Even a clamp with two pre-crimped cables would be fine with me as long as the connection is reliable.
