Squarebody brother
Registered Member
Was wondering if any rtv or other sealant is used on the one piece windshield seal on my k5 ? Putting one in on my Christmas break , any tips or advice would be appreciated much
How would you use this with the rubber gasket on the k5?
So you put the sealant on the Grove where the glass goes? Or both?you put a bead in the the groves. The weather strip with locking strip in center doesn't need to use a rope to install glass. I have removed and in stalled the rear window in pickups, for camper crawl through, many times with plastic pry levers. The non lock strip windshield seal could be done the same.
