Shackle flip and towing
Yup, but there is proof that you are wrong about this. This is a technical point of fact so there is no room for opinion, just facts about how a shackle system works.
All things totalled up, the overall package is what makes a tow rig work. You have to have a good trailer because a trailer that bounces all over the place is going to be miserable. You have to have good shocks with reasonable leverage against them. You have to have a stiff enough spring to handle the tongue weight without excess ride height changes. You have to have a stiff enough tire to handle the load without excess squirm or bounce.
1. I don't think so. Although this is a debate of technical fact, I do think there is one conclusion you need to draw from all of this, and it would be the answer to only one question. "Despite the tradeoff, is it worth if to me to run a shackle flip in my tow rig." My personal opinion is no, and that blocks or stiffer, more highly arched lift springs would perform this task better (and of course have other tradeoffs).
2. You are absolutely right. The way I look at it, the factory engineers rated these trucks for a certain load. Installing something like a shackle flip which by design has the potential to diminish load capacity to a degree that could be debated reduces the truck's load capacity. Whatever the new safe load that can be carried is, I cannot calculate, but I would be willing to speculate that it would be less than what was originally calculated for these trucks.
If what you say is fact and the effects of shackle angle on spring rate only come into play near or at the transformation from positive to negative arch, I would say the tradeoff is minimal.
However, I feel that an agressive shackle angle can and does cause a spring to feel softer over its entire range of travel as this has been my personal experience in the past.
I think that the majority of rigs that are towing will never see an issue, espeically if the trailer is loaded properly, has the proper frame mounted, weight distributing hitch, etc., and the tow rig is not overloaded. I just worry about that one guy that has his 1 ton truck loaded to full rated load, and I wonder if the stock rear springs with a shackle flip are really what I wanted back there at full load.
I know that new trucks come with up to 4" blocks from the factory. I also feel that if it was so easy and effective and safe for a heavy duty truck to have a compression shackle that the OEs would be doing this themselves just to save money on the 4" lift blocks some of their trucks are sporting from the factory.
Ahh...the endless debate. /forums/images/graemlins/rolleyes.gif I don't think either of us are wrong, I just think that a shackle flip is ill suited to towing by design.
Sometimes I wonder why i didnt buy the ORD flip. /forums/images/graemlins/doah.gif
I don't. It is a stronger design, but I like my echobit flip. Mine fits perfectly as it was hand made as one of the first ten that Mike brought to the market, however.....
I've got a lot of respect for the research and development that went on at ORD to produce their product.
Trust me in my real world experience, I am the idiot that will tow a 14,000 gvw trailer fully loaded behind my 3/4 ton truck. The funny thing about this truck is that I have towed the same loads with this truck when it was stock, lifted with blocks, springs, and finally a shackle flip. The biggest change I ever felt was when I lifted it 4" originally, the change from one type of lift to another really didn't change the truck from there.
The point that I will argue here is; my truck is an extended cab long bed 3/4 ton truck that is meant to tow and haul loads it doesn't matter how it is supported at one end of the spring. What I'm saying here is this, don't expect you blazer on 35" tires with a 4" lift and 4.10 gears with the sway bar removed to be the tow beast that a well setup 1 ton dually is.
Tim, the real point here is that there is technical proof that the shackle flip is safe for towing. You are always the first one to pipe up and state your OPINION like it is the gospel. Most people know this and are able to read between the lines with what you are saying. But those that don't know you will, never listen to the other side of the story. You can state your opinion but try to do it in a way that is only your opinion unless you can come up with valid and accurate tech. that proves that your view on the subject at hand is not just your opinion.
Ya. know a very inteligent man once told me not to get in a P$ssing contest with a skunk. In the end you end up smelling like a skunk and he enjoys it.
I'm out on this one.
I have an echobit too- there were minor fitment issues, but otherwise was an easy install-
However, getting an answer as to how many degrees to shim the spring pack, finding an answer was difficult, if not impossible. Towing answers, not really likely.
And should anything go wrong now... Do I have ANY warranty? Stephen's one really tall dude, at least I know I can find him to bitch and complain. /forums/images/graemlins/rotfl.gif. Same thing with AZ-kickin, I know I have someone I can instantly contact for support. /forums/images/graemlins/thumb.gif
Anyways, when "properly equipped" Yes, you can tow- But that means in my case with a flip-
Change the already soft stock springs for new/stiffer springs. Add air bags. Add overload springs- add E rated skinny tires. add WD/ sway setup. Add rear sway bar.
ok, if you do some combination of the above (and exactly which one will work for a particular person, I dont know)- You can tow just as much. A spring pack on a 3/4 or a 1 ton is already significantly stiffer compared to that of a 1/2 ton. 57" springs are gonna be even flexier.
I guess I'm done too, if we can't distill this down to concrete operating characteristics based on sound mechanics, then there is nothing more to say.
Thanks for the plug Pook, what you say is why we're here.
so Tim.
would you ever tow anything behind a s-10 series truck? Jeep?
early chevy truck? (and car for that matter?)
the main point is "If set up properly you can safely tow with a flip."
so Tim.
Tow with one of those vehicles?! /forums/images/graemlins/blush.gif You have got to be kidding. Towing with vehicles from the factory with a near 6000# tow rating? You are crazy! And with a factory compression shackle! Total death trap and driver should be shot on site! Imagine the nerve of people suggesting towing a properly equipped and loaded trailer with a capable vehicle!
I don't think anyone could ever tow with one of those vehicles! /forums/images/graemlins/whistling.gif
And the nerve of dodge to show the new durango towing a boat to the lake, they should show it in a ditch cause his shackles are wrong /forums/images/graemlins/histerical.gif
Here goes my 2 cents on the matter. I have ORD shackle flips on both of my K5s. I have a #/4 ton crewcab to tow with. I often use mt 73 K5 to tow my 16 foot and 22 foot car trailers instead of my crewcab to tow because I am driving that at the time of need to go where I need 4wd. I have never had a problem towing my loads with my 73 K5 that has shackle flips and 35 ATs. It handles like expected for a lifted truck and 35" tires. Make sure you have brakes on the trailer and an appropriate brake controller and dont act stupid and everything will be fine.
so Tim.
Nope. I usually only tow with my 1 ton truck because that was what it was made to do.
Gospel, hell no. I don't even fell that is is that unsafe, I do believe there are more ideal setups, that is all.
I do understand everyone's point in saying that it has been done sucessfully. Unfortunately that isn't enough for me.
I don't think it's suicide or anything, just not the optimum setup for towing.
Well I guess its 'safe' because I can see oncoming cars over the elevated hood. I was hoping I could bind the shackles somehow to releive some of the squat back there but the springs are so soft that it wouldnt really do much good /forums/images/graemlins/frown.gif
I'll have to borrow a tow rig if i need to haul the trailer any distance
They're a pain in the butt to install and un-install but you could try some of the bolt on overload spring kits that go on top of the leaf. I used a set on my wife's taco for a while when we were hauling a camper with it and they really helped keep the rear up where it needed to be. Maybe it needed.......
drumroll please........
tension shackles instead of compression shackles to be able to haul that 1/2t sized camper on a 1/4T truck.
Maybe a set of those coil spring helpers that go between the axle housing and frame would be helpful--I put the 1500 lb ones on my plow truck to help with the weight of the sand in the bed,and it rides and hadles a lot better--next time I'm going for the 2000 lb versions.They were 20 bucks at autozone.They clamp on easy with a large u-bolt,can be removed quickly too.
