Another out here in AZ....
Check out this 1987 k5 blazer for $11,000 on OfferUp.
https://offerup.co/zkBhSiXTM3
These trucks are gaining value no matter what year but you have to make sure you don't overpay or it will be a lifetime before you get back your money.Would you guys say there's any concern with going with a model above 1987 from a collector/ resale value situation? Like 1988 - 1991 before they changed over to that mid to late 90's body style?
I love the '87 and later squares. TBI just runs so much better than carbs. I have an '89 suburban, '90 K5 and '91 V3500. They all run great and I will not be going back to a carb. The late model trucks have a lot going for them.Is there any concern from a collector/ resale perspective for buying something newer than 1987 model? Like the 88-91 models before they changed to that mid-late 90's body style?
Yeah lots of weird things going on with this one. The gauge panel is from a diesel I believe. But the gauge cluster is from a gasser. If you look closely, you can see the AC compressor in one of the 1st underhood pics. It is in the factory location. If Tejas Steelworks motor mounts were used, the compressor can go back in the stock location with very little trimming done to the frame.20 grand is a big price for one of these. Even with the LS swap. Couple of red flags for me. They call out the trans as a th400. An 86 would have had a 700r4 od trans. So if they say it's a 3 speed it could be a th350 or th400. The th350 would require a kickdown cable hooked up to the throttle body which I can't see. The th400 would have an electric kickdown switch on the throttle pedal or firewall which I can't see in the pics either. No direct pic of the transmission pan to ID it either. Either trans is fine, but it does make one question what they were doing or if these guys even know and somebody else put it together.
Next flag is the a/c situation. The ad says both a/c and heat work. What I don't see is the compressor. Normally when you do an LS swap to one of these the a/c compressor in the stock LS location on the bottom pass side of the block you have to notch the hell out of the top of the passenger side frame rail to clear. Most use a bracket to relocate the compressor to the top passenger side to avoid chopping the frame. Again no clear pics of that either.
These kind of sales lots love to work the gas monkey style quick flip where it looks great on camera and get you sold and down the road. Personally I'd be very cautious with that one. See if you can get an impartial inspection at another shop so it can be looked over closely for any crappy work or questionable repairs.
I am in California and plenty of supplies of clean trucks.One of the main reasons I keep my Burb out of the dirt nowadays is the crazy way prices are going on them. It's just insane the prices of old cars/trucks/burbs are hitting now. That brings up a second point; when does the value of semi straight rust free blazer become so high it's just stupid to turn them into fun offroad vehicles that we'll just end up bashing up and then cutting up. It seems better to keep it clean sell it for a ton of dough and then get a shitty one and tear it up.
