CherryK5
they are such a hard compound, they will last you till they dry out.
ohhhhhhhh. Gotcha.
You might as well plan on putting that D60 in before you even think about those tires. And crossover steering is just the start. If you plan on being offroad with those tires other than dirt roads and the occasional mud hole you're gonna REALLY want hydro assist.
look at it this way
$50 tires and $2000 getting them to work "well" in your truck.
like others have already said. 52" front springs.
Both stock 52 and 56's will give you around 4" of lift. 56's are a little easier swap as you don't have to move the shackle hangar, but the 52's are generally easier to find IMO and there is no added benefit of the 56's over the 52's performance wise.
My 52's without bumpstops or limit straps will exceed the capability of my 15" shocks, ext brake lines, and driveshaft angles. I can't imagine any added flex of the 56's is really useful.
In a nutshell if you are going to run either of them use whichever you have on hand.
With the 52 swap most people have to move the shackle hangar forward to get a good shackle angle. With the 56's the added length gives you a good angle with the shackle hangar in the stock position. If you moved it forward with 56's the shackle would lay flat, or not reach at all.
The whole point of cross over is to make steering geometry better. Since the drag link is angled down to the tie rod (assuming you are lifting the truck) this does not help much.
If you aren't lifting the truck much like 4" or so yes that would work just fine, just need a dropped pitman arm that will get the drag link at a better angle.
That type of steering will never be as good as a true crossover, unless you run a panhard bar at the same angle as the drag link.
Steering is all about getting the angles on the drag link as parallel to the ground as possible. It also helps to have the drag link as long as possible.
If you ran that setup with highsteer arms then yes it would work dandy
This whole idea sounds like you just took the offramp from happiness highway, but are about to take a LONG drive down misery lane.
EVERYTHING about your current truck is going to be wrong once you add those tires. This sounds like one of those stories where the "free" parts end up costing you a TON of real, actual money over the next few years.
Caveat emptor!
someone always knows where to find a cheaper one of equal quality.
Pretty sure that's kert's whole game. My understanding of his operation is such that I don't see his cost of operation getting any cheaper, and a guy's gotta feed his family.
If you want cheap, you can always cut up what's already on your frame and use that, or make it yourself. I only see it being possible to cut out the cost or kert's labor and shipping. I don't think he's charging for much else.
You don't HAVE to run crossover with longer springs, but I don't see any point. The stock steering can't handle the roll travel of the stock springs, so increasing that is just going to make things less reliable and more screwy.
I personally feel the most economical way to do all this is just get a 60 and piece together your steering on the side. Swap it in when it's ready and try to trade your stock half tons for beer or something. Otherwise, you'll just spend money on stuff you won't keep. That, and if your looking for travel, you'll probably want big tires, and a locker, which means broken shafts...you'll want a 60 some day, and steering on a 60 is a pair of knuckles cheaper than a 44, and used steering arms are easier to find.
Whatever you do, leave the swaybar on until you fix the steering. If you're really broke, it's not worth braking the knuckle, and it's really easy to do if you're twisting the truck up and that steering is cycling vertically on those studs. That steering arm system is only designed for parallel force and when they brake, you'll be shopping for a pair of knuckles anyway. Might as well give yourself time and get a setup like ORU sells on your own time.
