Sm465 Transmission Question
Don't do what I did and sit there any worry about how to get it all done.
I rebuilt mine in an afternoon with a mini-sledge hammer, a couple blocks of wood, and snap ring pliers :D
Press is helpful if you've got access to one, as are bearing pullers, but you can usually manage without :)
Sounds pretty simple then. Since you have already gone through it, do you have any hints/sugestions from what you experienced. Did you just use the rebuild kit? Would you have replaced anything else?
thanks
