So tonight I just realized...
Avery4jc said:
... I never turned anything down because I didn't like the opinions I was being given...
:haha::haha::haha::haha::haha::haha::haha::haha::haha:
Avery4jc said:
I e-mailed superlift, edelbrock and rancho and have never received a response from any of them which is why I posted up again. Thanks to everyone for the info.!
eMail? I said CALL! Now will you turn down that opinion? BTW, telling people they can "take a hike" could be considered as turning them down.
C'mon! You are Bobby Hill aren't you? Ok, so he's a cartoon, but he is modeled on you right?
Scene:
The Garage
Hank (to Bobby):
Now gol' durn' it! Just hang on a darn minute there Bobby!
End Scene.
Avery4jc said:
Chris, BKinzey and Ben you guys are more than welcome to take a hike...I posted to get some info and I never turned anything down because I didn't like the opinions I was being given...
I've posted on this before but never got this sort of response...
Umm yeah you did, you were told in your huge cluster of a post a few months ago that cavitation becomes a problem when shocks are upside down... :rolleyes: :rolleyes: :rolleyes: :rolleyes:
I will avoid the discussion on theory and add some experience:
I had a twin tube mounted upside down for a while, but I can't remember why. It got air in the wrong place so it had zero damping for about an inch of travel centered at ride height, so it didn't work right. After I flipped it back to the right way up and cycled it a few times it worked fine again.
well my 02 has dual shocks up front. Each side has one mounted each way- rides better than before....
By the way, if you are on the cheap- check out superlift's ebay store- usually 10 bucks a piece
yeah thats what I'm going to order b/c I can't find anything else for 8" of lift and I know these work...
its what I have on here now but I was just checking the positioning issue before I ordered new ones and put them on wrong...
I think I'll order them and put the rear ones on since they have no clearance issues going the "right way"...then when I get x-over done this summer I'll pop the new ones on up front.
ok, well see before I thought my shocks drained out b/c they were on upside down...but now I know that you can mount them on upside down and if the seals are in good shape they won't leak they just won't work like they are supposed to...mine leaked probably due to age...
so iono about the mono-tube shocks...
Seconding Ramsey's comments, Mono-tube shocks (Bils, Kings, SAW's, Fox's, etc) are designed to be mounted body up - shaft down and can be reversed.
To avoid confusion those are the ONLY shocks I run that way. Everything else, including modern Rauncho's, get run body down. Real old Rauncho's were different, but that's not the case any more.
So, run Mono-tubes any way you want and twin-tubes body-down only.
Scene:
The Garage​
Hank (to Bobby):​
Now gol' durn' it! Just hang on a darn minute there Bobby!​
End Scene.​
:haha: :haha: That is the funniest thing I've seen in awhile, thanks BKinzey I really needed that.​
Anyway, Listen to what BAJA BLAZER has to say. He runs the baja race and if anyone is going to know anything about shocks, it would be him.​
BAJA_BLAZER said:
You couldn't be more wrong. Orientation of the shock has NO effect on valving. With a twin tube shock, if it is run upside down you will get more cavitation as the shock oil will move to the gas chamber and visa versa. The cavitation will cause more heat resulting in premature failure of seals.
This is the best commentary on the subject in this post:
Q: Can shock absorbers be mounted upside down (rod end down) and still function properly?
A. Most modern shock absorbers utilize a twin (dual) tube construction; in order to work properly the inner of the two tubes (working chamber) should stay completely filled with oil. The outer (reserve) tube contains an oil reserve along with air or a pressurized gas. If the unit is mounted inverted (rod side down), the air or gas in the outer chamber can enter the inner working chamber, resulting in poor damping performance. Therefore, twin tube shock absorbers should not be mounted upside down (or on their side), with the exception of specially designed units that incorporate a gas cell, or cellular gas material, designed to keep the gas retained in the outer reserve tube.
The best shocks are Mono Tube shocks, that is why they cost more. You can run them in any orientation and they would fix your problem.
Take a look at my Avatar; you'll see I have some experience running shocks upside down.
I just re-read the thread b/c I some how missed your post earlier...thanks for the info, that makes sense.
