I've just replaced the stock quadrajet with one from Summit Racing (nothing fancy). The new quadrajet didn't have an electrical connector (2 prong) at the front that appears to go to some sort of "double pump system". That part of the wiring also seems to go to a coolant sensor in the thermostat housing.
Is that additional pump critical - it seems to run great without it.. although the engine does occasionally diesel after shutting it off...
