Sources For Seat Belts?
Qubit
Redwood City, CA
Anyone know where to find new stock retractable shoulder seat belts?
It's one item that I'm not too comfortable picking up at a junkyard....
If you want "real" ones, try GM.
I'd be more comfortable with used GM belts than I would be with Chinese made ones.
JMO
I've been thinking about these for my 1st Gen.
<a target="_blank" href=http://www.andoauto.com/retrofit.htm>http://www.andoauto.com/retrofit.htm</a>
If you wheel, you don't want the retracts. Heck, if you were near by, I would trade you for a set of fixed belts. Bouncing around they tighten up eternally till you can't breath. I have had to stop and work them loose, and I often drive with one hand holding it up so it doesn't cut in too bad (which, of course, reduces it's usefulness).
