spare on fuse panel...?
walduniek
Registered Member
PA
Im want to run something off the fuse panel instead of wiring straight to the battery. My Question is: is there a spare slot?
The fuse panel is on a 86 Jimmy 305 manual
i tried to look at a wiring diagram but its not really helping.
I also looked ath the panel itself but Im not really sure.
fuse tap is your best bet. you can tap off of constant or key on fuse, make sure you do it on the power side of the fuse, not the powered though. Then you put a .250 female and wire to where you need it and its perfect.
Yeah from what Im seeing thats going to be my best bet... thanks
