bp71k5
3/4 ton status
Here's a weird one that has been bugging me the entire time I've owned the k5.
The rear driver side always sits about 1" lower than the passenger side. I've replaced the springs, swapped the springs, swapped the shackle brackets, everything I can think of. Then I found one of the spring perches damaged and replaced both and triple checked they were aligned when I welded them on.
After all this, nothing changed the ride height. And I haven't measured exactly, but it looks like my spring perches are not aligned anymore. (They seem to be at slightly different angles)
So my theory is that whatever damaged the spring perch originally may have caused one of the axle tube welds to break and the tube is turning inside the pumpkin once I tighten the u-bolts. Anyone have a good way to check this? I see two plug welds on each side of the pumpkin and the plugs on one side do look a little wet from oil.
How easy is this to fix? Is it better to just weld around the tube to keep it from rotating more or do I need to drill out the plugs and have those re-done?
