Dunno if anyone has done this but I think I fixed my hood latch today. It did the typical not popping up when released thing. You'd have to whack it at the center front to get it to pop up from the closed position. Got looking at the cable and realized what was happening was similar to the problem Ford Rangers have with the throttle cable.
It stretches and over time you loose the ability to hit WOT simply due to the fact that matting the gas pedal doesn't pull the throttle all the way open at the engine.
Expensive and PITA fix is a new cable.
Easy fix is a couple small zip ties wrapped between the end of the cable "ball" and the mount.
Worked great on the Ranger and I figured it couldn't hurt.
Sure enough it pops up every time now. We'll see if it's fully corrected but not bad for a few pennies.
