bp71k5
3/4 ton status
Ive developed a high idle after the truck warms up (1200rpm) on my tbi setup. Should I suspect a vaccuum leak or bad IAC?
You can "force" the IAC motor closed and then see what the RPM's are.
First you need to...
(1) Jumper the A and B terminals of the ALDL connector
(2) Key on, engine off (DO NOT start engine while ALDL is jumpered as you can blow the ECM)
(3) Wait 30 seconds then disconnect IAC wire connector (at TBI IAC motor)
(4) Remove Jumper wire from ALDL connector
(5) Start engine and observe engine RPM
In your case there are only a couple vacuum lines so i wouls start by plugging ALL of them (brake booster included) then see if the RPM's drop. If they do i would start by hooking the brake booster hose back up first then check again. If the brake booster diaphragm goes bad it will create a vacuum leak that will take you forever to find UNLESS you've had prior experience with a bad booster (go ahead, ask me how i know).![]()
Could you tell me how you know? I'm still having problems with my motor and I suspect a vac leak.
Thank you,
Ed
I assume you have checked the linkage back to the TBI unit so it is returning all the way closed. I have seen a worn TBI shaft stick a little open when close to closed/idle.
If you restart the engine when this happens does the idle return to normal?
Hmmmmm... I wonder if that PCV valve is bad? I have never noticed a lot of noise from them but some... can you put a vacuum gauge on the engine and see if the vacuum is steady at idle? Preferably a tee in the vacuum line to the MAP sensor.
I will look at my PCV valve later and see if it acts the same as yours. It is a controlled vacuum leak to evacuate engine of fumes but I never noticed if it was as eratic as you describe.
It's my second one, but I suppose it could be bad. It's only a year or so old. I have an old one I can try replacing it with to at least see if it's consistant.
Easier yet is to just remove and plug that vacuum port for testing purposes.
If it's fluctuating as you described it's driving the MAP sensor NUTS! Not good! Indacates a leaky intake valve. Unless you have a large cam, that's another bag of worms on a Spedd/Density system.
Cam is a TBI friendly version from a reputable builder.
