RedBrute
I have been putting up with this all winter and decided to tackle the problem this weekend
Engine is a TBI 350 with Thorley headers, Magnaflow cat, all else stock
Tuneup done last summer, cap, rotor, plugs/wires and coil. Timing set at 4*BTDC. All vacuum hoses vac checked for leaks, none found. Stock ACDelco fuel pump and filter along with new NAPA sending unit/fuel line assy.
The problem is when accelerating from a start and using just enough throttle to get the truck moving, the engine starts to bog and "load up" like a carb with a choke hanging. If I give slightly more throttle it appears to clear up and drives OK.
If cruising at say 35mph and just enough throttle to maintain speed it'll start to load up and"buck" until the throttle is depressed, it then clears up.
Outwardly the evidence is a black sooty tailpipe as well as slightly sooty plugs. Truck drives fine other than the bogging/bucking occasionaly and does not give a code.
The O2 sensor is a Bosch that is about 4 years old.
I have an old OTC monitor 2000 hand held diagnostic tool that allows me to scan thru various "modes" and look at IAC,TPS, BLM, O2 volts etc, as well as LED flags that indicate closed loop, open loop,TCC etc.
I went for a test drive and checked a number of things. Most important I think is the BLM, never gets above 108 while cruising at 65mph and the Integrator varies from 113 to 129. The O2 volts bounce all over the place, from .040 to .800.
I can get the BLM to increase but only when accelerating.
I tried a completely different TBI this weekend thinking my 250k mile original unit was tired. Other than a slightly lower idle it didn't change a thing.
I'm stumped, I have a lot of info from the diagnostic but don't have the experience to know what is right and what is wrong.
Any suggestions???
Any suggestions???
