Currently have a 1990 K5 (or V1500, not sure what they were identified as during those years...) with the 350 and throttle body injection. It has given me several problems since I bought it, mostly with electronics like the fuel injection, emissions control etc. Along with the rat's nest of wiring from the previous owner putting in his own "alarm system", aftermarket power windows, speakers with crossovers and using telephone wire to run a lot of that stuff, I'd like to strip most of it, start from scratch and wire only what's needed.
I'm hoping by doing this, along with replacing stuff like the distributor, switching over to a mechanical fuel pump, it will make things simpler down the road and diagnosing a problem wont't be as much of a guessing game.
What I'm looking for is some advice on what people think of this swap, is it worth it?
My plan, if I do go through with it, its to replace a lot of the components that were previously EFI compatible, like the distributor and fuel pump. Would I just look for parts for a pre-TBI 350, like for an 85 Blazer for example and just go from there? Or are there physical differences on a 350 TBI block and a pre-TBI block that make the older parts not compatible with the TBI 350.
Another thing I've come across is the transmission compatibility. I checked the RPO codes on the inside of my glove box, and I have MD8 on there. From what I've seen online, that means it's a 700R4, but I wasn't sure if they'd switched over to the 4L60 by 1990. I know people have to get another bracket for the kick down cable if they have a 4L60-E, but I'm not positive if that applies to 4L60, or if a 4L60 is just a re branded 700R4 so it wouldn't matter.
So if anyone has done this before and has an idea of what parts would be necessary to convert it, I could use the help.
, clean plugs). If wiring is really really bad, get an aftermarket harness and run it.
