454-502 Automotive TPI System w/ GM ECU & Harness. The ASM big block tuned port injection is designed for any cubic inch big block Chevy engine, oval or rectangle port, short or tall runner, we have them to fit any combination. The basic unit consists of a lower manifold assembled with the 30 lb./hr injectors, fuel rails and fuel regulator, upper plenum with linkage assembly, 58mm throttle body, GM computer with a custom program, complete wiring harness, all sensors, distributor and coil, high pressure fuel pump, K&N high flow air cleaner, and all mounting hardware
this is a 454 tpi kit i know. but this might be what he got from the dealer. they deal in high performance stuff for around here. i know the motor cost him like $4500 with everything
