I have a 71 jimmy that has been sitting for years. I have finally got to the point were it is ready for the road. All I need is the t case and tranny adapter. Anyone know where to get one. It has the bearing in it and does that come out?
Are you sure? I believe GM used th350/205 combo for around 10 years in the late 60's early 70's.
I've seen this 350/205 combo used from the late 60's clear up to 1980.Are you sure? I believe GM used th350/205 combo for around 10 years in the late 60's early 70's.
I have one for sale for $135, it is the one without the bearing.
I'm interested in hearing about them used up to '82 since the K5, 10 and 20 used the 208 case beginning in '81.
1980 was the last year of 205's in the above said rigs. And we all know the K30's carried them up to '91.
Interesting theory about the grooves worn in the older sleeves though.
I spoke with an outfit in Colorado and they said that you can use a 27 by 27 spline sleeve that goes over the 2 male shafts. If that is true I would not need the bearing adapter, corect
The synchros were around '83 and '84. I've got an '83 sitting in my shop and its synchro'd.Didnt Chevy use the NP205 in 1982 with the syncro front output? Anyone know what trans came in front of those models?
Not quite that simple.So I could use an adapted without the bearing set up, and just use a sleeve?
