I'd like to post my application and if there is a thorough link discussing the ins and outs, I would be grateful. Searching with key words of 700r4 swap ends up with a lot of unrelated threads for some reason.
My truck is an 85 long bed K10 with a TH350/NP208 set up. The truck came with a 700r4 and a PO swapped in the TH350. I want to swap a 700r4 back in since I installed 4.56 gears. 3 gears is not cool now. Most of my searching on the web ends up with car or 2wd truck applications discussing tail shafts, drive shaft mods, etc. My main question is since its 4wd with a t-case, will a 700r4 bolt right in to the NP208 in its present location? I know I need to move the cross member back but I should be able to just go back to the original holes. I thought the main case of the 700 was longer than the th350.
I'm not sure about TC lock up connections or the tranny cooler lines or what's needed to go to the TV cable. Can someone give me a clear break down of what is compatible and what will need moving/fitting/modding? I know it's a common topic but it's not as easy as it seems to find all the info I need that varies depending on the application. Thanks for any help.
