ToWmaterK5
Registered Member
I just converted my rig to TH400auto & doubled cases. It shifts on the road 1 thru 3 late and then shifting suddenly/harsh. My hallucination: "I did get it to shift into 4th gear on the road only after getting my speed maxed out and backing off the pedal. But, can't get it back into 4th again", so I'm doing 45-50mph in 3rd at 4000 RPMs.
Its shifting and works, but I'm going too far between shifts at high RPMs.
The transfer cases was in high range(203) front axle neutral, rear axle High(205). The vacuum line is connected to the Quadra-Junk carb. Could it be I'm not generating enough vacuum?
I do have a RV cam...its nothing/not a huge racing cam or anything.
Any ideas where to start?
I deserve it
With the late and hard shifts...other than bolting it up and running the vacuum line is there anything else with the TH400 that I'm not doing.
I'm going to Rehab now.
