The 20 year Truck
I'm planning on building up a K5 blazer into what I call my "20 year truck". By this I mean a vehicle that I can use as a reliable daily driver, capable of mild off-road work, and reliable enough to get our of dodge in an emergency situation.
I'm really excited to get started into the project but I need to do a bit more planning, and find the base K5.
Because of financial reasons I can really only have 1 motorcycle and one truck at a time, so this vehicle must function as a daily driver as I do the upgrades (With the obvious intermitten down time for upgrades). In order to do this I plan on doing it in 3 phases. Phase 1 will be corrosion prevention and hardening the powertrain, and doing regular maintenence and repairs on the entire vehicle. Phase 1 being the only time the vehicle is unusable for an extended period of time.
Because this is to be a daily driver, and I'm not a 4x4 guru. I would like to keep the engine close to stock (thanks to all those who helped answer those questions for me earlier). I'm interested in running 33" tires.
The first question is concerning axels and differentials. I've always wanted a selectable locking rear differential. However I've heard that the stock 10 bolt axels may not be up for the task. Will I have an issue running 10 bolts with 33" tires?
Thanks for your input, I'll have a lot of questions to ask as I plan out this build. I really appreciate your advice!
