The Bent77 K10: Orange Parts
Average User Rating:
5/5,
  1. Bent77
    Bent77 Desert Solitaire Premium Member GMOTM Winner
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    Have a line on another complete 32 spline 465. We'll get to that later
    Pulled the 465. Missing the front 1/8" of the reverse gear and back 1/8" of the 1-2 gear. Slides into 2nd fine with the cover off, but doesn't fully engage 2nd with the shifter on. All I can determine at this point is the gears got together and the shifter no longer hits 2nd
    For reference, I was in 2nd and going downhill when it went BANG
    203 looks just fine. Detents appear correct, if anything the sloppy position is the high range stop.
    Didn't look in the 205. Pretty sure it will be fine after I hit it with a hammer
    Going to go through each piece with it out of the truck and the covers off, make sure each shifter position is 100%
    That's all I got...
  2. sreidmx
    sreidmx Fortify Offroad Vendor
    Oct 24, 2013
    6,586
    4,933
    Morongo Valley Ca
    Build(s):
    5
    Sounds not good.. bummer man.
    F.S.F.W likes this.
  3. 454Sub
    454Sub 5/8 ton status Premium Member
    Apr 11, 2012
    2,642
    963
    Southern Illinois
    Build(s):
    I tested mine with the PTOs off. It's how I figured out my 205 wasn't right the first time.
    I now regret my doubler crossmember blocks access to the 205 cover. It's a great diagnosis setup.
    F.S.F.W and Bent77 like this.
  4. 454Sub
    Apr 11, 2012
    2,642
    963
    Southern Illinois
    Build(s):
    Something else I though of. Mine had sloppy detents in the 205, so I polished the shift shafts (insert pun here) and shimmed the detent balls down quite a bit. It makes an audible"click" when it engages. I then did the same to the 203 later after I felt it too was sloppy.
    Bent77 and F.S.F.W like this.
  5. F.S.F.W
    F.S.F.W Caught up in the movement Premium Member
    Feb 9, 2016
    5,997
    5,820
    Douglas Wyoming
    Build(s):
    Depends on who's teeth they are... right Mark? :haha:
  6. Bent77
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    I'll look into that, thanks
  7. Bent77
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    Um yeah
    F.S.F.W likes this.
  8. 454Sub
    Apr 11, 2012
    2,642
    963
    Southern Illinois
    Build(s):
    You need to polish all those shafts!
  9. JoshHefnerX
    JoshHefnerX 1/2 ton status Premium Member
    Jan 7, 2015
    2,825
    1,415
    Glendale, AZ
    Build(s):
    Weren't you have a problem w/ something shifting initially when you installed it..? Too lazy to go back and look.
  10. Bent77
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    I didn't think so.
  11. Truckman4life
    Truckman4life 3/4 Ton Status Premium Member
    Feb 17, 2010
    1,780
    1,576
    Rigby, ID
    Build(s):
    3
    How did you get home with this thing?
  12. Bent77
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    Drove it. First to third sucks
    tRustyK5, ZooMad75, ashman and 3 others like this.
  13. sreidmx
    Oct 24, 2013
    6,586
    4,933
    Morongo Valley Ca
    Build(s):
    5
    With tbi but had it been a 6.deuce ... wouldn't have sucked..
    GWeakland620 likes this.
  14. Bent77
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    Correct
    Justin V, 78K30 and sreidmx like this.
  15. sreidmx
    Oct 24, 2013
    6,586
    4,933
    Morongo Valley Ca
    Build(s):
    5
    Bet that gear gap got real big on hills
  16. Bent77
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    With 4.10s and 37s, Vail pass and Eisenhower was slow
    78K30 likes this.
  17. 454Sub
    Apr 11, 2012
    2,642
    963
    Southern Illinois
    Build(s):
    A 6.2 would have blown that 465 into bits.
  18. Truckman4life
    Feb 17, 2010
    1,780
    1,576
    Rigby, ID
    Build(s):
    3
    Did u just throw some new oil in and hope for the best?
  19. skunked
    skunked in the garage Premium Member GMOTM Winner
    Feb 27, 2013
    10,189
    8,710
    Placer County CA
    Build(s):
    It was funny watching @bent72 leave the campground on the highway, rev 1st out to redline and then bog into 3rd lol
    AgDieseler, 82355, 78K30 and 2 others like this.
  20. Bent77
    Dec 3, 2002
    13,883
    13,635
    colorado
    Build(s):
    Nah it was already broken
