CK5 Network
Become a member of the largest online community for Chevy K5 Blazer, Suburban and C/K series truck owners!
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
bent72 submitted a new Build:
the-bent77-k10-Does not do automatics
Index:
page-1 leaf spring/steering talk
page-3 flat tops and tire balancing, Lift, D44 powr lok, leaf spring spec link
page-6 7747 ECM talk, fender cutting
page-12 5215 bilstein shocks
page-16 hidden winch mount
page-21 14BSF ARB install
page-27 Busted parts - Drive line stuff
page-30 rocker protection
page 34 High Pinion perch part 1
page-40 hand throttle
page-46 rear bumper build
page-50 CB, TBI air cleaner flow
page-52 rear diff guard
page-53 finally more High Pinion info, air cleaner mods
page-55 High Pinion housing build stuff
page-59 High Pinion housing installation
page-61 Original engine modifications discussion
page-62 First steering shaft upgrade (XJ steering shaft)
page-63 high pinion pictures - gear installation
page-67 Safety Harness with bench seats and seat cover link
page-77 2nd upgraded steering shaft with better parts
page-87 of fuel tanks and Fitech FCC, injection, and doublers
page-98 Doubler Parts
Sweetk30's triple stick link: 4l80-e-to-203-range-box-to-205-ord-doubler
page-103 Machining the 205
https://ck5.com/forums/threads/the-bent77-k10-let’s-do-moab.322474/page-108#post-3717786 203 cleanup
page-109 ATF in t-cases - synthetic oils
https://ck5.com/forums/threads/the-bent77-k10-let’s-do-moab.322474/page-113#post-3729649 203 - doubler assembly
https://ck5.com/forums/threads/the-bent77-k10-let’s-do-moab.322474/page-119#post-3739588 37s show up
page-128 Front Fender re-radius
page-131 Doubler cross members link
doubler-link-sticky Doubler Sticky
page-140Doubler install
page-143 Crossmember for doubler
https://ck5.com/forums/threads/the-bent77-k10-let’s-do-moab.322474/page-148#post-3789308 Bitchen T case Shift knobs
page-148 where to drill your steering box
page-166 BB17 Busted 465 forks and pissed off 205s
page- https://ck5.com/forums/threads/the-bent77-k10-let’s-do-moab.322474/page-169#post-3811389
203 detent modification
https://ck5.com/forums/threads/the-bent77-k10-steering-box-stuff.322474/page-177#post-3821047 Cool winch plate stress simulations
page-183 Engine swap talk (11 more pages of fun)
page-205 31 gallon tank planning
page-211 New engine
page-212 tank install
page-218 New filler set up
page-221 Skid plate start
page-227 Skid plate installed
page-257 Fittings from TBI tank to AN fuel lines
page-260 Holley EFI
page-261 -6 Fuel pressure fitting/gage
page-278 Edelbrock Pro-Flo 4
https://ck5.com/forums/threads/the-bent77-k10-let’s-do-moab.322474/page-289#post-3956393 205 output bearing
page-303 Fuel filter madness
Read more about this build here...
blazinzuk
Buzzbox voodoo
Premium Member
Afton / Star Valley Wyoming
I love begged borrowed acquired builds.
My tow rig is that.
My jimmy is that.
Horton is mostly that.
Only suggestion I have is be flexible. But you probably know that we'll enough. The other thing is save 500 bucks or so. That way when the deals are there you can jump on em.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Hey, long time no see! All due to my fault. Ran a few trails with you BB'11
Yep, I have a small slush fund for such acquisitions, and some leftover parts as well.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
So, after talking with @63chevyII about spings and such, going with longer springs on the rear (as edited above, 58"). Planning on hanging those off of some ORD 2.5" flips with super shackles.
still planning on the 52" out back currently going up front. Likely going to do the ORD kit up there too. Fact is, too lazy to fab everything from scratch anymore!
max 02
N.E.D.
Premium Member
Clive Alberta Canada
My tow rig is that.
My jimmy is that.
Yup! pretty much how my 77 was created too! :popcorn:
82355
1 ton status
Premium Member
Bradish Nebraska
Use a set of 2wd hangers for your shackle flip if you are looking to do it on the cheap.
Martin
82355
1 ton status
Premium Member
Bradish Nebraska
Also, what ORD kit for the front?
On my 1990 Blazer, the front body mounts were removed from the frame (all three pieces still riveted to each other) and then swapped side for side. That is the cheapest way to do the 52" springs on the front. My front upper shackle hangers were still in the stock location.
Martin
max 02
N.E.D.
Premium Member
Martin
Martin
Both things I what to do to mine! But I can`t afford the crossover steering.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Yes sorry i didn't specify, the ORD kit is the arm, histeer arm, draglink, ends, bolts for the knuckle, etc.
When I built the 72 I used a 2wd box with a cherokee arm machined to accept a 3/4" heim, machined my own histeer arms, built my own drag and tie rods from scratch. I no longer have free iron laying around or easy access to machine tools.
The front leaf spring business however will be all chop and flop.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Martin
Good info, been awhile since I built a rig, a little rusty on some of the good interchange info. Thanks
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
The cross over is a must in the good rocks. I started the 72 without the crossover, night and day difference in the change.
82355
1 ton status
Premium Member
Bradish Nebraska
Do crossover, skip the High Steer. DIY4X is now offering crossover steering, their prices are pretty reasonable.
Martin
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Martin
I have considered that, but long run I will likely also go hydroassist, and i liked having that whole mess above the axle tube. I would have killed the last set up without histeer.
No doubt though DIY has some good stuff, had some of his parts on the '72.
bp71k5
3/4 ton status
Premium Member
Knoxville, TN 37922
72 is gone huh. I remember that one. Anyone buy it that will drive it and not part it out or anything?
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
One of the guys here on the board bought it, sounded like he was planning on wheeling it. I'm sure there will be some things he changes, but he was looking for something to beat :)
Not wheeling the rental this year?
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Haha, you remember that? No more wheeling rentals for me. Bashing the bumper on a rental is more expensive than driving my own junk out. :)
Hey that was a good time! I'm going to try and push for BB16, hopefully we'll see you there
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Agents of evil looking for parts, doing a little up keep . Cancer creeping in again, looking to cut most of it out and assess the sliders and mounts.
blazinzuk
Buzzbox voodoo
Premium Member
So I agree with just crossover no hi steer. I have 56s in front with assist. Too much stuff yup there. And I wheel only rocks. Make that tie rod super beefy. .250 wall is for mall crawlers
