Confedneck
3/4 ton status
35's still rub with 6" of lift. It's a fact. 38's would rub a hell of a lot.
RIZ
I'm not scared of a nibbler and paint work, nor am I scared to run a narrow tire and the right offset wheels. There are ways to keep tires from rubbing. You would probably also guarantee that every stock k10 with worn out springs would rub with 33s and no lift, as well as have massive axle wrap, but you'd be wrong about that, too. Not every truck is the same, not every wheel is the same, and not every wheel and tire combo is the same. Once again, there ain't exactly a whole bunch of off-camber stuff around here.
