umm, air down your tires before you wheel.
And XJ steering shaft swap. You could get one at a junkyard for like 10-25 bucks
what are the advanges of these things?muddermilitia said:XJ steering shaft swap. You could get one at a junkyard for like 10-25 bucks
howdiy said:I'm not going to bother buying that![]()
1978Blazerk5 said:what are the advanges of these things?
Tighten up your steering. Plus I have seen rag joints fail under hard use1978Blazerk5 said:what are the advanges of these things?
87BrnRsd said:Thats what I thought for a while too. Luckily my frame hasnt actually cracked yet, but the steering has started to really suck on the trail lately. The box has started to pull at the bolts to the frame and has started to warp the frame there. Very very close to cracking it but im not gonna wheel it again until I brace it.....because im almost positive it will crack if I wheel it hard again.![]()
-Harrison
dhcomp said:Extend the breather hoses for the front/rear diff.
broncoman6524 said:would you care to explain the headlight realy mod? does it make them brigher of cause less power draw?
