Break out your tapes and calipers so you can play along at home. If you haven't had the pleasure of reading Part I of this series, you can find it here. If you have any of the commonly used stock GM springs at home (48, 52, 56, 60, 63", etc.) or any commonly available lift springs (especially from this list) go measure them and post up the dimensions in this thread. I'll crunch the numbers and compare 4 different equations for estimating spring rate.
The dimensions I need are:
L = the length along curve of the main leaf from the the center of one eye to the center of the other
L' = (optional) the distance between the u-bolt centerlines on the same u-bolt. If not provided I will assume 3.5"
N = the number of leaves NOT counting the overload
N' = (optional) the number of full length leaves (usually 1, a military wrap = 2)
W = the width of the spring
T1, T2, etc. = The thickness of each leaf starting at the top measured at the center of the spring (again exclude the overload) Note: the spring rate is highly dependant on leaf thickness, make sure you can accurately measure it to at least 1/32" for best results.
A = (optional) the free arch of the spring
For non-symmetric springs (like 56" springs) I'll also need:
a = the length of the spring ahead of the axle (about 30" for a 56" spring)
b = the length of the spring behind the axle (about 26" for a 56" spring)
A picture would be great as well.
The four equations are:
1. SAE HS-788, R = 32*E*sum(I)*SF/L^3
2. Chassis Engineering, R = ((W X N) / 12) X ((1000 X T) / L)^3
3. Ranger Station Calculator (actual equation unknown, but suspected to be identical to #2 with the exception of an optional adjustment for leaf taper)
4. Equations from a thread on Pirate R = ((2+(N'/N))*(E)*N*W*(T^3))/(6*(L/2)^3)
The other parameters not listed in the dimensions above are:
R = the spring rate in lbs/in (note this is the raw design rate, the as-installed rate will vary depending on the shackle angle etc.
E = Modulus of Elasticity in Tension (about 30,000,000psi for most steels)
I = the Moment of Inertia of a single leaf. Note, this is not a standard Moment of Inertia calculation, HS-788 has a big look-up table that accounts for the unique shape of a leaf spring.
SF = Stiffening Factor. This factor accounts for leaf taper and spacing. Without going into it all, I am going to assume SF=1.15 for everything unless I get a pick of a non-standard looking spring pack (i.e. with leaves pulled out). In that case I might go with SF=1.10
Note: I am going to use the active length for L whenever possible (L-L').
The CK5er who posts up the most useful information will win a cool prize!*
*not really
*not really
A perfect compliment to my awful front shackle angle.
Well, now I know what to expect when I finally drive it for the first time. I'll bring a kidney belt.
