The re-bent72, Bruiser
Tags:
  1. 6872xtc
    6872xtc make mine modified Premium Member GMOTM Winner
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    6872xtc submitted a new Build:
    Read more about this build here...
  2. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    We left with this on the trailer about 5:30, stopped in Glenwood Springs for a burger (which took forever that night) , changed a flat on the trailer 40 miles away from home, and unloaded at 10:30 p.m.
    I am not sure why the Cummins pick-ups were going so slow....
  3. Bent77
    Bent77 1 ton status Premium Member GMOTM Winner
    Dec 3, 2002
    15,273
    15,308
    colorado
    Build(s):
    This looks familiar!
    bmxbryant9 likes this.
  4. Bent77
    Dec 3, 2002
    15,273
    15,308
    colorado
    Build(s):
    Maybe best thread title ever!
  5. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    If you would post some pictures of it, please!
    So my daughter started naming my trucks several years ago, and after a few weeks, this got named "Bruiser "!
    It doesn't have a straight panel on it, and it's black and blue!
    It has a 350 which is built very nicely! TBI and a performer cam and intake. Sm465 / 205, with 4:56 gears. D60 front with ARB, 14 rear / Detroit, crossover, hydro assist, good condition 37" MTRs.
  6. Bent77
    Dec 3, 2002
    15,273
    15,308
    colorado
    Build(s):
    I don't want to hi jack your thread, but I can add some back story wth pictures if you want
    bmxbryant9 and 6872xtc like this.
  7. bmxbryant9
    bmxbryant9 Let's go wheelin Premium Member GMOTM Winner
    Jan 10, 2014
    988
    1,134
    Petaluma
    Build(s):
    Sounds like it's just about ready to hit the trails! Haha it looks sweet
    wetoolowdingbangow likes this.
  8. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    Now keep in mind that since it has been goin' wheeling for years, I don't have too much to do to it, and I don't have the time or budget to do too much.
    But I had a DIY4X razorback cover for a 14B sitting here waiting, but it needed some serious trimming to go on this one!
    Look at the bottom bolt.
    I told the previous owner that @500$k5 had shown me some of his wiring skills over the years and I would change a few things. So Pat built me an Iceberg case CS130.
  9. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    But since it had factory '72 brackets on it, it took a little work to install the serpentine pulley alternator.
    I already had the bracket setup here, the PSC pump on the K5 has a press style shaft, so I needed to do some work! I drilled the extra hole in the right cylinder head by laying on the radiator support, my ribs didn't like that. ..
    Change the water pump, and then drill, tap a hole in the intake to install the ECM temp sender to move it from the T it was in. Now I have a valve on the coolant going to the heater to cool the interior a little. I had to cut some of the right serpentine bracket off since I didn't have one like my '95. That let me re-use the lower hose.
    Bent77 likes this.
  10. Bent77
    Dec 3, 2002
    15,273
    15,308
    colorado
    Build(s):
    I will start by apologizing toany and all 1st Gen owners. It was a mostly decent truck when I started, body wise anyway
    True story oddly enough, I bought this so as to not cut up the '77 Scottsdale I still have.
    My previous wife made one good decision in begging me to buy something else to wheel
    Nothing, literally, in the drivetrain worked right.
    My original plan, as it was supposed to have 3.73 gears, was 33s, couple posis & lift, drive it.
    Had to hold it to the floor in 3rd gear to go 45.
    3.08 gears, jetted for sea level, 2* lead and 3 different heat range plugs.
    Bought it the day after Thanksgiving 2002
    Within a month, I pulled both axles, rear seat, grille, bumpers, and sold them.
    Did a valve job in the garage, replaced the cam and intake. and looked for axles
    Got a D44 from Toby Irwin (Moneypit), with Warn shafts and an ARB. Smoking deal. One and the same axle Toby said Steve Fox once owned.
    Pulled the 14bff from another guys Blazer who is no longer on the board, Brian (87blackK5)
    37s new on 15 wheels
    Did all the stuff to make that work.
    Which included cutting 2 trash cans worth of metal
    NorCal69 and 6872xtc like this.
  11. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    I needed some stretch in the upper hose that I had laying around, so I found a leftover piece of aluminum tube, and made a set of old vice grips into a beading tool, this is what I came up with.
    Bent77 likes this.
  12. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    I will attest to the fact that it will run over 70 with NO problem now!
    Bent77 likes this.
  13. Bent77
    Dec 3, 2002
    15,273
    15,308
    colorado
    Build(s):
    Yeah, it gets scary at 100!
  14. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    A side project was the front markers. My son's '72 was purchased new by my dad, so I have looked at them horizontal for decades. My wife even commented on them. So now they are like this
    bmxbryant9 and Bent77 like this.
  15. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    So for one weekend, my messy garage looked like this while I did the serpentine conversion. It not often that the wife's Acadia sits out! Bruiser got to sleep inside for one night!
  16. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    I replaced the charge wiring and also found that the main power to the cab was just about to fall apart! I think that it had been shook lose from a previous encounter pulling a CJ7!
    So I found a D60 razorback cover for it! Thanks @mrk5 ! But my finger is too small too fit in the 3/8 pipe bung that they come with, so it now has a 3/4" pipe bung! And a fresh blast/ paint job!
    mrk5, bmxbryant9 and Bent77 like this.
  17. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    I forgot, the engine fan is for a 6.0 vortec. It's on a TBI engine fan clutch. It fits well in the '72 shroud. Thanks @azblazer !
  18. F.S.F.W
    F.S.F.W Caught up in the movement Premium Member
    Feb 9, 2016
    6,930
    6,813
    Douglas Wyoming
    Build(s):
    Wait?!?!? Your finger is too small??? @bent72 was picking on me earlier so I'm just passing it on.
  19. 6872xtc
    Sep 16, 2008
    2,896
    1,736
    Palisade,Colorado
    Build(s):
    Yeah, it is! I tell my wife that my pinky is 10" though!
  20. F.S.F.W
    Feb 9, 2016
    6,930
    6,813
    Douglas Wyoming
    Build(s):
    Haha!!!!
