Yes, you have a 1/2-ton emissions intake manifold ("C-code"). The picture below shows what a dual-plane non-emissions J-code manifold looks like. These were used on 3/4-ton and 1-ton trucks. The opening is larger, and these are air-limited engines. I noticed a difference when I swapped out my C-code manifold.
These two cover most 6.2 trucks, but there are a few more intake manifolds used on these engines (6.5TD manifolds are a bit different on top to accommodate the turbine plenum). @AgDieseler has at least half of them hanging on his wall...![]()
So it’s probably not as simple as removing the EGR valve, is it? Need to replace the whole manifold?
