The Ruffstuff 14Bolt Complete Swap Kit!
i have a van width 14bff will your bolt on disk brake adapters work with this i think its the same as a srw just a little wider i believe the hubs are srw hubs
will this work with 15 inch wheels i don't mind slight grinding on the calipers but i do drive this on the street so i don't wanna grind too much
i saw somewhere that you will customize the kit i don't need the diff cover how much would the rest of the kit cost thanks
With steel wheels it should be fine, Aluminum wheels are all different thicknesses and I would say nothing under 16" and even then some 16's will not fit.
Give us a call for a smaller package...
looks nice on my axle. now I just need to get those spring perches and shock mounts welded on.
The diff cover does if you want countersunk, not if you do not because everyone has a different idea of what grade to use. The countersunk are grade 12 but if exposed I would use grade 5 because they will mash up but a grade 8 would be more prone to shearing off.
On the pinion guards we do not as of today but we have ordered 4,000 bolts so we could get the price down and when they arrive we will start adding them.
