Throwout Bearing Failure
irokgmc
Morgan Hill, CA
When I was driving today I started to hear a chattering coming from my tranny under load. I am going out of town so I don't have time to tear into it today, I figure to start with the throwout bearing and see if that is bad. Any other suggestions of what to look at?
You might want to inspect your drive line too..the noise might be missleading you? TO bearing should only be spinning when you engage the clutch, under load the fork should have pulled it away from the press. plate. Spend some time under there and inspect...
Good Luck!
