hughmungas
Registered Member
I want to cut the end of my NP208 transfer case shaft off at the output side so I can drill a hole and then cut threads in it to secure a SYE. The reason I want to cut the end off is that it is hardened steel and you can't drill through it without pulling it out and putting a torch to it to change the properties. I don't have a torch and don't really want to pull it all apart and reassemble it and so was thinking I could just cut the tip off to get past the hardened part and drill and thread a hole.
The question is, how much would I need to cut off of the shaft to get past the hardened part?
