Tire manufacture date
The proper pressure depends on the load rating of the tire, the size and the weight on it.
Ok...
Picked them up this morning from discount..
Will install on my next day off...
I feel weird having wheels so shiny. Doesn’t match the overall “look” of my blazer. Hahahahahah
Have to order new lug nuts. The ones I have are too big for a socket to fit around in the wheel slot and not long enough to even tighten down
I mean they fit as they are 7/8 inch but there is absolutely no space for a socket.
So I got 9/16-18 3/4 hex. And 1.92 in lug nut length.
After I ordered from amazon I saw there is a 1.66 length. So I may go that route if the 1.92 stick out too far.
I ordered these
https://www.amazon.com/DPAccessories-D3313-2305-32-Chrome-Closed/dp/B00I6SE5DQ/ref=mp_s_a_1_31?c=ts&dchild=1&keywords=Wheel+&+Tire+Lug+Nuts&m=A2A65CUIZM9PM8&qid=1605207239&refinements=p_6:A2A65CUIZM9PM8&s=automotive&sr=1-31&ts_id=15706641
But also saw these is case the above stick out too far:
https://www.ezaccessory.com/Long_Bulge_Acorn_Lug_Nuts_Thru_Hardened_p/2010l.htm
Make sure you dont need longer studs . Some aluminum rims are THICK and require on our older trucks a longer studs to get lug nut engagement correct.
Bare min 5 - 6 full turns on the lug nut to stud is required .
Since the lugs nuts are so short I couldn’t really tighten it down. They would sit flush in the new wheel and I wouldn’t be able to remove it. But I will double check engagement when the new lugs nuts arrive.
In the event I need new studs, could you link the proper length ones or the extended ones? I have 3/4 ton axles
DORMAN
98718.1
9/16-18 Serrated Wheel Stud - .625 In. Knurl, 2-1/8 In. Length
Application Summary: Chevrolet 1991-75, Chevrolet 1973-72, GMC 1991-75, GMC 1973-72, Jeep 1988-74
This what you have now. You can go to the Dorman chart and see what they have. You have to keep the same measurement from the flat side of stud to the end of the stated knurl and the diameter of knurl. Also thin wall socket is advised.
DORMAN
98718.1
Yeah I see the thin walled socket. With the lugnut I had no way any socket would fit in there.. Hahahahah
Thanks for the info
I’ve swapped a few broken ones on my old C10’s. I assume instillation is going to be different with these?
I’m going to have to defer to member expertise here. I’m a bit lost on sizes. I took screen shots of what seem ok for a longer stud but not really sure what I need as far as a longer stud...
This is what you need to pay attention to (xxx) for you new length if needed.
Product Specifications
Color: Silver
Head Diameter: 0.875 in xxx
Knurl Diameter (In): 0.625 in xxx this size or if you drill larger.
Package Contents: 1 Stud
Quick-Start Nose: No
SAE or Metric: SAE
Shoulder Diameter: 0.624 in xxx
Shoulder Length (In): 0.906 in xxx this is a biggy, these are for rotor and hub
Shoulder Thickness: 0.21 in xxx
Stud Material: Steel
Style: Serrated Stud
Thread Diameter: 9/16
Threads Per Inch: 18
Under Head Length: 2.125 in xxx
Package Quantity: 1
Thread Size: 9/16- 18
Packaging Type: Bag
Thread Length (In): 1.22 in xxx length of stud for wheel
Thread Handling: Right Hand Thread
OE Numbers
