What is the torque spec on 8 lugs? 80ft pounds?
What psi is good for daily? 30ish?100 - 120 ft lb range
If you have 9/16 studd .
@TJ1978 after you drive it around a bit recheck the torque on those aluminum wheels
yes 100 to 120 range is fine .Yes 9/16
Make sure you dont need longer studs . Some aluminum rims are THICK and require on our older trucks a longer studs to get lug nut engagement correct.
Bare min 5 - 6 full turns on the lug nut to stud is required .
Yeah I see the thin walled socket. With the lugnut I had no way any socket would fit in there.. HahahahahDORMAN
98718.1
9/16-18 Serrated Wheel Stud - .625 In. Knurl, 2-1/8 In. Length
Application Summary: Chevrolet 1991-75, Chevrolet 1973-72, GMC 1991-75, GMC 1973-72, Jeep 1988-74
This what you have now. You can go to the Dorman chart and see what they have. You have to keep the same measurement from the flat side of stud to the end of the stated knurl and the diameter of knurl. Also thin wall socket is advised.
