y5mgisi
1 ton status
Some crazy 1250 amps or something like that!
I have a hard enough time remembering the stock belt route.......
I just had an idea to make a "cheap" diesel-electric. Start with a small diesel and cover it with alternators - maybe 15. I have no idea what the longest stock serpentine belt available is. Use ground isolators for them so they all go in series. When running you get over 200V to charge a bank of 15 car batteries in series. Then you build electric drive without using a high voltage inverter. Run the electric motor straight to the driveshaft (or TC) low differential gears. To get fancy, build the speed control to run in 4 quadrants for regen braking.
Well that would power the new HID offroad lights no problem
