Too Nice to Tear Up
12 years trying to daily drive a 1978 K5, while making it a great Moab rig.
I'd be afraid to go anywhere alone with that guy..... :haha:
Regardless, you have a very nice Blazer and it's a bit of a sleeper IMO.
I've known him for about 30 years. So I guess I can trust him LOL. Thanks for the compliment on the Blazer. That's what I've tried to build. Something that works well, without spending a lot of money.
Time for a front bumper. 3/8 plate to bolt to the frame. Cut frame rails back to tuck in bumper as close as possible.IMG_0332.JPG IMG_0328.JPG IMG_0331.JPG
Needed to curve the bumper, slightly. Thanks to my uncle, for the use of his plasma cutter! Two cuts, for a slight bend.IMG_0334.JPG
Holes cut for d-ring mounts. made out of 1x2 solid steel, run through bumper, and welded to the frame plates.IMG_0335.JPG IMG_0336.JPG IMG_0337.JPG
Love this K5, definitely is a sleeper. Don't forget when @K85 Octane and I talked you going up Potato Salad Hill and tossing your power steering pump out...
ahahaha
it was afraid, poor truck got halfway and said NOPE! eFF THAT!!
Nice truck that went everywhere, damn pump was the only thing stopping it from making it up
Hey I want license plates the "THE". I think it's fun when you get a plate that actually spells something.
Noticed that the bottom of the frame rails, were sticking down like a couple of rock gougers. Made a lower rock slider to cover frame rails, with braces, to prevent the bottom from caving in when I drop off of "The Fall" on Steelbender. LOLIMG_0388.JPG IMG_0392.JPG
Added a removable top cover, with diamond plate, to protect the cut down license plate, and to prevent my stupid ass, from falling off, while installing a new power steering pump, in the NAPA parking lot in Moab, after someone convinced me to try to go up Potato Salad Hill.@BabaganooshIMG_0399.JPG IMG_1798.JPG
700r4 and 208 installed. Used the '81 and newer trans tunnel and shifter. It fit the '78 floor, with only a couple of extra holes needing to be drilled. The 208 shifter even covered up the 203 shifter hole in the carpet. Combined the wiring, so the 4wd light even works in the dash. Used a '82 and newer PRNOD21 installed in the '78 gauge cluster.
Can't bash a 208, like you can a 203, so a new skidplate, and cross member were fabbed. 2X2 box tubing, 1 3/4" roll bar tubing, and 1/4" plate were used. Bolts onto the original cross member with hidden bolts, so nothing to hang up on. Roll bar tubes extend forward, to help protect drive shaft.IMG_3195.JPG IMG_3196.JPG IMG_3197.JPG IMG_3198.JPG
IMG_2768.JPG IMG_2772.JPG IMG_2773.JPG IMG_2774.JPG "Lift Kit" installed. LOL Stock factory springs. 1" zero rate blocks from Offroad Design, on the front. Front axle moved forwards 1". for inner fender clearance. 4" lift Rancho 5000 shocks. Needed the extra shock length, to allow for spring droop. Also needed longer brake lines for the extra suspension droop. Added springs to the brake lines, to allow them to move around when drooped out, but not get into the front tires, when not flexed out. 2" blocks on the rear to make up for the amount of crap, that I bring with me.
Added a 2" drop pitman arm, to try to get more steering, when drooped out on the drivers side. Yes I know, CROSS OVER STEERING, but it won't fit with my puny lift. LOLIMG_5672.JPG
Rear bumper further modified. LOL Bend on left side, is from a Chevy Colorado, and a Ford Raptor, trying to pull this turd, out of a snow drift. They had to strap themselves together, and actually tore the rear frame rail on the Blazer, when they hit the end of the tow rope.IMG_3186.JPG
